Regulator Rectifier Wires
Vinnie
Hello out there, can anyone help me please
I bought an old SRAD 750 recently and found it wasn't charging. I bought a new reg -rectifier but now I come to fitting it I found that the plug it connects too has been butchered. The red and white and the black and white wires out of the rectifier still connect through the plug but the three black wires have been bypassed straight to the next plug. What I need to know is, as these wires are all coloured black does it matter which order they connect to the new rectifier black wires or do I need a new loom? Any help gratefully recieved thankyou
intrepid
Some bikes have black wires and some yellow. There should be three wires and they supply the AC voltage to the rectifier. They can be wired in any order. Would be worth checking you have equal voltage on each wire - if not then your stator will need changing before you get the right voltage from the reg/rect
