no electrical power
homerhobson
Il cut a long story short i melted a rectifier bought another that preceded to over charge the battery so whilst in the process of removing the 2nd one i touched two of the wires { yes i know should have disconnected the battery my fault} and the original connector melted hence the 2nd rectifier was simply spaded together. Now i have no power to anything except the neutral light. No indicators No head lights No fuel pump nothing the main 30 amp fuse is OK the ignition fuse in the front fuse box is OK the CDI unit iv swapped just in case nothing am i missing another relay somewhere that switches on power to everything the manual has nothing in it it simply mentions the main starter relay and the turn and fuel pump relays. There's a diode i believe not got to this yet you would almost think there is another main fuse hidden away somewhere that is preventing main power to all things. All help willingly accepted
Ben
