Clutch problem
Mulchie
7
Hi all. I am unable to engage the clutch on my 96 SRAD 750. When checked, the cable is free and I have replaced the actuator/wormgear. When I pull tthe clutch I can feel resistance and see the wormgear turning and pushing the pushrod. However, when engaged and in gear the rear wheel remains engaged in gear and cannot be turned. Cable adjustment appears correct as I know this is usually the problem, but I am thinking the clutch needs inspection. It feels like the pushrod cannot compress the clutch enough to engage it.
Any ideas? .
Mulchie
7
You get this fixed?
I did. I used a different engine oil as I noticed that the new oil I hsd used was thicker and appeared to be sticking the plates together. The new oil change did the trick. The change is still heavy, but much better than it was.
