Six pot brakes.
Russ
Bedlington, northumberland
Hello, I have just joined club so if this has already been discussed please forgive me! I have gsxr750wp, can later model six pot brakes be fitted to my bike? If so, do I need to change discs etc? Thanks, russ.
As far as i am aware the discs stayed the same. I had a 600 srad with 4 pots on but i just swapped the for 6 pots. They bolted straight up.
Your discs are 310mm i think and the SRAD is 320 but that wont make a difference as the caliper mounts will be in the correct place.
Are the calipers 100mm centers or 90mm?
Russ
Six pot brakes
Hi,thanks for reply, my calipers are 90mm centres, is this significant?
I was not sure if the earlier bikes were 90mm. there are some oddball 6 pots that are 100mm and the later stuff is 67mm (if i remember)
I believe i have a set of 90mm 6pots if you get stuck. With matching master cylinder.
