newbi needs wiering help
dave2207
hi all*iv just brought my first srad*it was running fine*striped it to clean it as i have slight ocd lmao!*now i have no spark now*i can turn thw ignition on all the clocks work can pull the clutch press the start and it will turn over but no fire*have wipped the plug out and had a look to conferm this.*hope someone can helpim thinking cdi unit?????regards dave.
They dont usually just die. Did you have any thing unpluged when you cleaned it?
Have a look at the diagram and make sure you have power were its needed. If you are not good with diagrams give us a shout and i will tell you where to check.
Also check the bid block connector under the left front fairing this has been known to cause this kind of fault.
if push comes to shove i have a spare SRAD ecu.
