Got another question.
I changed my stock indicators on my 2000 gsxr 750, I did the front ones a couple of days ago and all was good, I fitted a led flasher relay and the blink rate is fine.
Today I changed out the rear ones and had to wire the datatool alarm/immobiliser that is fitted to the bike into the rear indicators as they were wired in on the old stock ones.
I also added a dual camera to the bike which is wired into the ignition fuse.
Now I have a solid FI light on, I've put it in dealer mode with the engine off and the code is -C00 which as far as I've found means no fault.
Anyone else had problems after adding led indicators?
I'm going to go and disconnect things tomorrow but figured I'd ask in case anyone has any ideas.
