What size rear tyre is best?
Baylissboy
11
Stoke-on-Trent
I'm going to be doing a track day on my 1000K4 & I was wondering which rear tyre size you guys were using?
Obviously standard size is 190/50/17 but I've heard of people using 180.55/17 to "quicken" the transfer from right to left & vice versa.
Any thoughts?
Underdog
Oct 24, 2016
227
The 180 would in theory make it flick faster but as with everything, where you gain in one place you lose in another and at a guess(and it's only a guess) I'd say you would lose stability at speed, how much you'd lose I couldn't say but the contact patch would be smaller
Tarmac
19
Hemel Hempstead, UK
I run a 190/55/17 on my 1000L3 found it quickened the turn rate nicely for me, and as a thought, they have changed to a 190/55 at the rear on the new GSXR this year.
Groke
Just got me a 750 K4. It has 190 rear tyre. Should I switch back to original sizing 180/55?
I have understood 190 is too wide for 5,5" rim.
Tarmac
19
Hemel Hempstead, UK
Hi Groke,
if your just using your bike on the road then i would suggest using the standard 180.
I always used the standard size on my old K8 750, there is a lot of choice out there depending on your riding style and what you use your bike for.
regards
Tarmac
Baylissboy
11
Stoke-on-Trent
Hi guys,
I did the track day....rained for 1/2 the day.....so going out with any size Supercorsa would have been a bad idea!!
I did go for a 190/55/17 which did work very well when it did stop raining!!
I've got the track day bug now...so I've sourced a pair of spare wheels so I can run wets if required. I've got a pair of Pirelli Diablo wets fitted to them.
I'm also looking at having a third set of wheels so I can run slicks. I've been looking at Metzeler Comp K's which are basically a road type tyre construction but with no tread pattern.....anybody tried them?
Peter Czibolya
17
I have used 195/65 KR108 MS02, 200/60 SuperbikeSC2, 200/655 V02 Medium, 195/55 D211 tires at the racetrack all of them was very good on the OEM 6" RIM.
The worst size was the original 190/50 flat profile tire...
Server Costs
Total amount
$0.00
Goal
$30.00
Advertisment
