Firing a K8 after years of standing
mk101
A friend of mine has an immaculate low miles K8 750 which he last rode several years ago before letting it stand (indoors).
If it was an older bike I'd empty the tank and drain the carbs before refilling the system with fresh fuel and attempting to start it but I'm not sure what's best with this bike with injectors. After draining the tank is there any way of removing the old fuel downstream of the tank in the pipework feeding the pump (if it's not in the tank) & injectors?
Thanks!
Smokey Pete
Probably not much in there if any from sitting for a while.
I would try starting it with super unleaded in the tank.
The oil might be a bit shit though
mk101
Yesterday we tipped out the old fuel and poured some fresh in.
The lithium battery still showed 13V (there must be zero parasitic drain from the aftermarket dash) but I gave it a brief charge anyway.
It started on the button! The engine must have only turned over 2 or 3 times before it fired up. OMG. Purred like a kitten. Let it run until the cooling fan kicked in. I get anxious if I let a bike stand for 8 weeks 😆
